Hi, newbie need help
Hi all, I’m a GL iNet newbie.
From a remote PC I need to connect to a target PC of my LAN using OpenVPN
Can you sugest a model of GL iNet product to buy to do this?
Thanks
Flea
Is using OpenVPN mandatory or would Wireguard be fine as well?
Could be work software Teamviwer? :thinking: So any Routers
Every VPN is fine for me
Well, not possible. The target PC is an industrial device (no Windows OS)
Put simply, almost all GL.iNet models can do this.
The question is what other requirements you have. Spontaneously, I would recommend the Flint (GL-AX1800) Dual-Band Gigabit Wi-Fi 6 Router
At the end, you can just decide by using this chart:
If your employer is picking up the tab & space isn’t an issue, look at the Flint 2 (GL-MT6000). If space constraints choice, Slate AX (GL-ATX1800)… but mind the port counts.
/ 0.02USD
