Renato
December 26, 2024, 7:36pm
22
dandek:
Why not have integration that can be set up in gui, display number of connected host, devices, cpu usage, mem usage, have a slider button to turn wifi ssid on off, reboot router etc.
Now I guess I started to understand...
Would you like to see these information from the router IN HOME ASSISTANT?
Why not simply run Tailscale on both your router and server, and then connect them?
Or also Googcloud
Both are native on GL-iNet routers.
dandek
December 26, 2024, 7:42pm
23
Because the whole point of smart home is to have it as much as possible on local control. That is why home assistant and not something else. That is why running zigbee devices, esphome devices and cut everything else that need internet cloud to work to bare minimum.
Renato
December 26, 2024, 7:50pm
24
Much easier, just connect it to your Home Assistant by the local IP.
On HA, you just need to create a view with a panel and a single webpage (iframe) card on.
system
Closed
July 20, 2025, 9:54am
26
