Hi All,
I am trying to set up home VPN server and let my travel router connect to the home vpn server. But so far, I could not get it work. Could someone give me some suggestions?
My home VPN server is Beryl, GL-MT1300-08d, firmware version: 3.215
My travel router is SlateAX, GL-ATX1800-39f, firmware version: 4.1.0
I am using wireguard on both routers. Below is the config I copy from server and paste in the client
[Interface]
Address = 10.0.0.2/32
ListenPort = 39304
PrivateKey = sBxV3NN5aXMywhOZh7on3U66sNo/AtvpU+beRLiDGXY=
DNS = 64.6.64.6
[Peer]
AllowedIPs = 0.0.0.0/0,::/0
Endpoint = 70.xxx.xxx.218:51821
PersistentKeepalive = 25
PublicKey = TfX3TT72t+l3GQSSo2DEtGizM/vCeygWzZW0AqHVURQ=
And this is the log file.
"Fri Jan 13 17:59:57 2023 daemon.notice netifd: Interface ‘wgclient’ is setting up now\nFri Jan 13 18:00:02 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Jan 13 18:00:07 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Jan 13 18:00:12 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Jan 13 18:00:18 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Jan 13 18:00:23 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Jan 13 18:00:28 2023 user.notice wireguard-debug: USER=root ifname=wgclient
I also use this website https://www.portchecktool.com/ to check port forwarding. After doing some research, the result I got from this website indicates that my ISP router port forwarding is working, but the VPN server itself is not letting the connection to be established.
