Horizontal Scroll Reversed
Horizontal scroll is reversed on remote computer. It's correct locally when tested in the same applications.
Any ideas?
it's a bug , we will see how to fix
It seems PIKVM is the same, not sure why it's designed this way. This won't be changed in the short term.
Ok thanks for the update
