I bought a GL inet AR750S-EXT and want to use it for a hotel, which allows only one device.
Several devices from my side shall then connect to the router.
Based on some entries it shall be possible. I tried it at an airport and it worked.
I already disabled DNS Rebind Attack Protection, to get it working for the airport.
Now I was using my android smartphone, connecting to AR750 5Ghz Wifi.
Connecting with Hotel Wifi is o.k., but then redirect leads to 192.168.1.250:8083 and replies with ânet::ERR_ADDRESS_UNREACHABLEâ.
Entering correct transfered Url also does not work.
Using other smartphones connected to Hotel Wifi routes and translates correct.
I got the complete system log and seen the following part within:
Sun Jun 16 06:46:47 2019 user.info : [ 145] gl-wifi-core>> (HTML) new session initâŚ
Sun Jun 16 06:47:18 2019 user.info : [ 243] gl-sdk>> session delete ⌠Token invalid!
Sun Jun 16 06:47:20 2019 user.info : [ 162]: gl-sdk>> (FCGI) new session initâŚ
Sun Jun 16 06:49:39 2019 user.info : [ 145] gl-wifi-core>> (HTML) new session initâŚ
Sun Jun 16 06:49:53 2019 user.info : [ 243] gl-sdk>> session delete ⌠Token invalid!
Sun Jun 16 06:58:24 2019 daemon.notice netifd: wwan (10085): udhcpc: sending renew to 192.168.8.250
Sun Jun 16 07:04:43 2019 daemon.err gl_monitor[3526]: Failed to connect to the switch. Use the âlistâ command to see which switches are available.
Sun Jun 16 07:13:24 2019 daemon.notice netifd: wwan (10085): udhcpc: sending renew to 192.168.8.250
Sun Jun 16 07:19:41 2019 user.info : [ 145] gl-wifi-core>> (HTML) new session initâŚ
Sun Jun 16 07:19:51 2019 user.info : [ 243] gl-sdk>> session delete ⌠Token invalid!
Sun Jun 16 07:20:54 2019 daemon.notice netifd: wwan (10085): udhcpc: sending renew to 192.168.8.250
Here the full logâŚwhen I got the permission I will upload
Here an extract:
Sun Jun 16 06:21:11 2019 daemon.notice netifd: Interface âwwanâ is setting up now
Sun Jun 16 06:21:11 2019 kern.info kernel: [ 89.651564] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
Sun Jun 16 06:21:11 2019 daemon.notice netifd: wwan (4843): udhcpc: started, v1.28.3
Sun Jun 16 06:21:11 2019 daemon.notice netifd: wwan (4843): udhcpc: sending discover
Sun Jun 16 06:21:11 2019 daemon.notice netifd: wwan (4843): udhcpc: sending select for 192.168.8.93
Sun Jun 16 06:21:11 2019 daemon.notice netifd: wwan (4843): udhcpc: lease of 192.168.8.93 obtained, lease time 3600
Sun Jun 16 06:21:11 2019 daemon.warn dnsmasq[2968]: no servers found in /tmp/resolv.conf.auto, will retry
Sun Jun 16 06:21:11 2019 daemon.notice netifd: Interface âwwanâ is now up
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: reading /tmp/resolv.conf.auto
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using local addresses only for domain test
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using local addresses only for domain onion
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using local addresses only for domain localhost
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using local addresses only for domain invalid
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using local addresses only for domain bind
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using local addresses only for domain lan
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using nameserver 8.8.8.8#53
Sun Jun 16 06:21:11 2019 daemon.info dnsmasq[2968]: using nameserver 8.8.4.4#53
Sun Jun 16 06:21:11 2019 kern.info kernel: [ 90.244744] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Sun Jun 16 06:21:11 2019 kern.info kernel: [ 90.251526] br-lan: port 3(wlan1) entered blocking state
Sun Jun 16 06:21:11 2019 kern.info kernel: [ 90.257036] br-lan: port 3(wlan1) entered forwarding state
Sun Jun 16 06:21:11 2019 daemon.notice netifd: Network device âwlan1â link is up
Sun Jun 16 06:21:15 2019 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Sun Jun 16 06:21:17 2019 kern.notice kernel: [ 96.020288] random: crng init done
Sun Jun 16 06:21:17 2019 kern.notice kernel: [ 96.023813] random: 6 urandom warning(s) missed due to ratelimiting
Sun Jun 16 06:22:39 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 06:22:39 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 06:22:39 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:22:39 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 RADIUS: starting accounting session 84ABF948E0DCBB8F
Sun Jun 16 06:22:39 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 WPA: pairwise key handshake completed (RSN)
Sun Jun 16 06:22:43 2019 daemon.info dnsmasq-dhcp[2968]: DHCPDISCOVER(br-lan) ac:5f:3e:79:b8:89
Sun Jun 16 06:22:43 2019 daemon.info dnsmasq-dhcp[2968]: DHCPOFFER(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89
Sun Jun 16 06:22:43 2019 daemon.info dnsmasq-dhcp[2968]: DHCPREQUEST(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89
Sun Jun 16 06:22:43 2019 daemon.info dnsmasq-dhcp[2968]: DHCPACK(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89 Samsung-Galaxy-S7
Sun Jun 16 06:22:45 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:22:45 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: disassociated
Sun Jun 16 06:22:45 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 06:22:45 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 06:22:45 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:22:45 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 RADIUS: starting accounting session 84ABF948E0DCBB8F
Sun Jun 16 06:22:45 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 WPA: pairwise key handshake completed (RSN)
Sun Jun 16 06:22:53 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 06:22:53 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 06:22:59 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: disassociated
Sun Jun 16 06:22:59 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 06:22:59 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 06:22:59 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:22:59 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 RADIUS: starting accounting session 84ABF948E0DCBB8F
Sun Jun 16 06:22:59 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 WPA: pairwise key handshake completed (RSN)
Sun Jun 16 06:23:00 2019 daemon.info dnsmasq-dhcp[2968]: DHCPDISCOVER(br-lan) ac:5f:3e:79:b8:89
Sun Jun 16 06:23:00 2019 daemon.info dnsmasq-dhcp[2968]: DHCPOFFER(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89
Sun Jun 16 06:23:00 2019 daemon.info dnsmasq-dhcp[2968]: DHCPREQUEST(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89
Sun Jun 16 06:23:00 2019 daemon.info dnsmasq-dhcp[2968]: DHCPACK(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89 Samsung-Galaxy-S7
Sun Jun 16 06:23:00 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:23:00 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: disassociated
Sun Jun 16 06:23:00 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 06:23:00 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 06:23:00 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:23:00 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 RADIUS: starting accounting session 84ABF948E0DCBB8F
Sun Jun 16 06:23:00 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 WPA: pairwise key handshake completed (RSN)
Sun Jun 16 06:23:01 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:23:01 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: disassociated
Sun Jun 16 06:23:01 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 06:23:01 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 06:23:01 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 06:23:01 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 RADIUS: starting accounting session 84ABF948E0DCBB8F
Sun Jun 16 06:23:01 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 WPA: pairwise key handshake completed (RSN)
Sun Jun 16 06:23:47 2019 user.info : [ 145] gl-wifi-core>> (HTML) new session initâŚ
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319113] ath: EEPROM regdomain: 0x80fa
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319120] ath: EEPROM indicates we should expect a country code
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319124] ath: doing EEPROM country->regdmn map search
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319127] ath: country maps to regdmn code: 0x37
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319132] ath: Country alpha2 being used: FR
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319135] ath: Regpair used: 0x37
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319140] ath: regdomain 0x80fa dynamically updated by user
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319211] ath: EEPROM regdomain: 0x80fa
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319214] ath: EEPROM indicates we should expect a country code
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319217] ath: doing EEPROM country->regdmn map search
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319220] ath: country maps to regdmn code: 0x37
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319223] ath: Country alpha2 being used: FR
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319226] ath: Regpair used: 0x37
Sun Jun 16 06:27:45 2019 kern.debug kernel: [ 483.319229] ath: regdomain 0x80fa dynamically updated by user
Sun Jun 16 06:27:51 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Sun Jun 16 06:27:51 2019 kern.info kernel: [ 489.542099] wlan-sta: deauthenticating from dc:9f:db:62:13:fd by local choice (Reason: 3=DEAUTH_LEAVING)
Sun Jun 16 06:27:51 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Sun Jun 16 06:27:51 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Sun Jun 16 06:27:51 2019 daemon.notice netifd: Network device âwlan-staâ link is down
Sun Jun 16 06:27:51 2019 daemon.notice netifd: Interface âwwanâ has link connectivity loss
Sun Jun 16 06:27:51 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Sun Jun 16 06:27:51 2019 kern.info kernel: [ 489.968283] device wlan1 left promiscuous mode
Sun Jun 16 06:27:51 2019 kern.info kernel: [ 489.973082] br-lan: port 3(wlan1) entered disabled state
Sun Jun 16 06:27:51 2019 daemon.notice netifd: Network device âwlan1â link is down
Sun Jun 16 06:27:51 2019 daemon.notice netifd: Interface âwwanâ is disabled
Sun Jun 16 06:27:52 2019 daemon.notice netifd: wwan (4843): udhcpc: SIOCGIFINDEX: No such device
Sun Jun 16 06:27:52 2019 daemon.notice netifd: wwan (4843): udhcpc: received SIGTERM
Sun Jun 16 06:27:55 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Sun Jun 16 06:27:55 2019 kern.info kernel: [ 493.595074] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Sun Jun 16 06:27:55 2019 kern.info kernel: [ 493.680034] br-lan: port 3(wlan1) entered blocking state
Sun Jun 16 06:27:55 2019 kern.info kernel: [ 493.685577] br-lan: port 3(wlan1) entered disabled state
Sun Jun 16 06:27:55 2019 kern.info kernel: [ 493.691422] device wlan1 entered promiscuous mode
Sun Jun 16 06:27:55 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Sun Jun 16 06:27:55 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e6:95:6e:47:78:28 and ssid âGL-AR750S-828â
Sun Jun 16 06:27:55 2019 daemon.notice hostapd: wlan1: interface state COUNTRY_UPDATE->ENABLED
Sun Jun 16 06:27:55 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Sun Jun 16 06:27:56 2019 kern.info kernel: [ 494.497815] IPv6: ADDRCONF(NETDEV_UP): wlan-sta: link is not ready
Sun Jun 16 06:27:56 2019 daemon.notice netifd: radio1 (9002): Successfully initialized wpa_supplicant
Sun Jun 16 06:27:56 2019 daemon.notice netifd: Interface âwwanâ is enabled
Sun Jun 16 06:27:57 2019 daemon.warn dnsmasq[2968]: no servers found in /tmp/resolv.conf.auto, will retry
Sun Jun 16 06:27:57 2019 daemon.notice netifd: Interface âwwanâ is disabled
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 495.780981] wlan-sta: authenticate with dc:9f:db:62:13:fd
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 495.799262] wlan-sta: send auth to dc:9f:db:62:13:fd (try 1/3)
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 495.833526] wlan-sta: authenticated
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 495.972939] wlan-sta: associate with dc:9f:db:62:13:fd (try 1/3)
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 495.993448] wlan-sta: RX AssocResp from dc:9f:db:62:13:fd (capab=0x421 status=0 aid=1)
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 496.001691] wlan-sta: AP has invalid WMM params (AIFSN=1 for ACI 2), will use 2
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 496.009484] wlan-sta: AP has invalid WMM params (AIFSN=1 for ACI 3), will use 2
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 496.017183] wlan-sta: associated
Sun Jun 16 06:27:57 2019 daemon.notice netifd: Network device âwlan-staâ link is up
Sun Jun 16 06:27:57 2019 kern.info kernel: [ 496.024006] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
Sun Jun 16 06:27:58 2019 kern.info kernel: [ 496.686536] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Sun Jun 16 06:27:58 2019 kern.info kernel: [ 496.693270] br-lan: port 3(wlan1) entered blocking state
Sun Jun 16 06:27:58 2019 kern.info kernel: [ 496.698811] br-lan: port 3(wlan1) entered forwarding state
Sun Jun 16 06:27:58 2019 daemon.notice netifd: Network device âwlan1â link is up
Sun Jun 16 06:27:58 2019 kern.info kernel: [ 496.707059] wlan-sta: deauthenticating from dc:9f:db:62:13:fd by local choice (Reason: 3=DEAUTH_LEAVING)
Sun Jun 16 06:27:58 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Sun Jun 16 06:27:58 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Sun Jun 16 06:27:58 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Sun Jun 16 06:27:58 2019 daemon.notice netifd: Network device âwlan-staâ link is down
Sun Jun 16 06:27:58 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Sun Jun 16 06:27:58 2019 kern.info kernel: [ 496.757665] device wlan1 left promiscuous mode
Sun Jun 16 06:27:58 2019 kern.info kernel: [ 496.762392] br-lan: port 3(wlan1) entered disabled state
Sun Jun 16 06:27:58 2019 daemon.notice netifd: Network device âwlan1â link is down
Sun Jun 16 06:28:07 2019 user.info : [ 1255] gl-wifi-core>> wifi(radio) scan failed. Use phy to scanâŚ
Sun Jun 16 06:28:07 2019 kern.info kernel: [ 505.864460] IPv6: ADDRCONF(NETDEV_UP): tmp.phy0: link is not ready
Sun Jun 16 06:28:09 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Sun Jun 16 06:28:09 2019 kern.info kernel: [ 507.891759] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Sun Jun 16 06:28:09 2019 kern.info kernel: [ 507.954408] br-lan: port 3(wlan1) entered blocking state
Sun Jun 16 06:28:09 2019 kern.info kernel: [ 507.959970] br-lan: port 3(wlan1) entered disabled state
Sun Jun 16 06:28:09 2019 kern.info kernel: [ 507.965858] device wlan1 entered promiscuous mode
Sun Jun 16 06:28:09 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Sun Jun 16 06:28:09 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:47:78:28 and ssid âGL-AR750S-828â
Sun Jun 16 06:28:10 2019 kern.info kernel: [ 508.321784] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Sun Jun 16 06:28:10 2019 kern.info kernel: [ 508.328551] br-lan: port 3(wlan1) entered blocking state
Sun Jun 16 06:28:10 2019 kern.info kernel: [ 508.334073] br-lan: port 3(wlan1) entered forwarding state
Sun Jun 16 06:28:10 2019 daemon.notice hostapd: wlan1: interface state COUNTRY_UPDATE->ENABLED
Sun Jun 16 06:28:10 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Sun Jun 16 06:28:10 2019 daemon.notice netifd: Network device âwlan1â link is up
Sun Jun 16 06:28:12 2019 user.info : [ 1261] gl-wifi-core>> wifi(phy) scan failed. Use wlan to scan
Sun Jun 16 06:28:19 2019 user.info : [ 2069] gl-wifi-core>> bIsStaEnabled=1
Sun Jun 16 06:28:19 2019 daemon.notice hostapd: wlan1: interface state ENABLED->DISABLED
Sun Jun 16 06:28:19 2019 daemon.notice hostapd: wlan1: AP-DISABLED
Sun Jun 16 06:28:19 2019 daemon.notice hostapd: wlan1: CTRL-EVENT-TERMINATING
Sun Jun 16 06:28:19 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan1 disabled_11b_rates=0
Sun Jun 16 06:28:19 2019 kern.info kernel: [ 517.828838] device wlan1 left promiscuous mode
Sun Jun 16 06:28:19 2019 kern.info kernel: [ 517.833613] br-lan: port 3(wlan1) entered disabled state
Sun Jun 16 06:28:19 2019 daemon.notice netifd: Network device âwlan1â link is down
Sun Jun 16 06:28:20 2019 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Sun Jun 16 06:28:20 2019 kern.info kernel: [ 519.053512] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Sun Jun 16 06:28:20 2019 kern.info kernel: [ 519.079348] br-lan: port 3(wlan1) entered blocking state
Sun Jun 16 06:28:20 2019 kern.info kernel: [ 519.084897] br-lan: port 3(wlan1) entered disabled state
Sun Jun 16 06:28:20 2019 kern.info kernel: [ 519.090964] device wlan1 entered promiscuous mode
Sun Jun 16 06:28:20 2019 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->COUNTRY_UPDATE
Sun Jun 16 06:28:20 2019 daemon.err hostapd: Using interface wlan1 with hwaddr e6:95:6e:47:78:28 and ssid âGL-AR750S-828â
Sun Jun 16 06:28:21 2019 daemon.notice hostapd: wlan1: interface state COUNTRY_UPDATE->ENABLED
Sun Jun 16 06:28:21 2019 daemon.notice hostapd: wlan1: AP-ENABLED
Sun Jun 16 06:28:21 2019 kern.info kernel: [ 519.574105] IPv6: ADDRCONF(NETDEV_UP): wlan-sta: link is not ready
Sun Jun 16 06:28:21 2019 daemon.notice netifd: radio1 (9903): Successfully initialized wpa_supplicant
Sun Jun 16 06:28:21 2019 daemon.notice netifd: Interface âwwanâ is enabled
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.781535] wlan-sta: authenticate with dc:9f:db:62:13:fd
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.799912] wlan-sta: send auth to dc:9f:db:62:13:fd (try 1/3)
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.813552] wlan-sta: authenticated
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.853337] wlan-sta: associate with dc:9f:db:62:13:fd (try 1/3)
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.864255] wlan-sta: RX AssocResp from dc:9f:db:62:13:fd (capab=0x421 status=0 aid=1)
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.872501] wlan-sta: AP has invalid WMM params (AIFSN=1 for ACI 2), will use 2
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.880095] wlan-sta: AP has invalid WMM params (AIFSN=1 for ACI 3), will use 2
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.887791] wlan-sta: associated
Sun Jun 16 06:28:22 2019 daemon.notice netifd: Network device âwlan-staâ link is up
Sun Jun 16 06:28:22 2019 daemon.notice netifd: Interface âwwanâ has link connectivity
Sun Jun 16 06:28:22 2019 daemon.notice netifd: Interface âwwanâ is setting up now
Sun Jun 16 06:28:22 2019 kern.info kernel: [ 520.895722] IPv6: ADDRCONF(NETDEV_CHANGE): wlan-sta: link becomes ready
Sun Jun 16 06:28:22 2019 daemon.notice netifd: wwan (10085): udhcpc: started, v1.28.3
Sun Jun 16 06:28:22 2019 daemon.notice netifd: wwan (10085): udhcpc: sending discover
Sun Jun 16 06:28:23 2019 kern.info kernel: [ 521.408429] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
Sun Jun 16 06:28:23 2019 kern.info kernel: [ 521.415200] br-lan: port 3(wlan1) entered blocking state
Sun Jun 16 06:28:23 2019 kern.info kernel: [ 521.420688] br-lan: port 3(wlan1) entered forwarding state
Sun Jun 16 06:28:23 2019 daemon.notice netifd: Network device âwlan1â link is up
Sun Jun 16 06:28:24 2019 daemon.notice netifd: wwan (10085): udhcpc: sending select for 192.168.8.93
Sun Jun 16 06:28:24 2019 daemon.notice netifd: wwan (10085): udhcpc: lease of 192.168.8.93 obtained, lease time 3600
Sun Jun 16 06:28:24 2019 daemon.notice netifd: Interface âwwanâ is now up
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: reading /tmp/resolv.conf.auto
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using local addresses only for domain test
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using local addresses only for domain onion
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using local addresses only for domain localhost
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using local addresses only for domain invalid
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using local addresses only for domain bind
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using local addresses only for domain lan
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using nameserver 8.8.8.8#53
Sun Jun 16 06:28:24 2019 daemon.info dnsmasq[2968]: using nameserver 8.8.4.4#53
Sun Jun 16 06:28:27 2019 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Sun Jun 16 06:30:25 2019 user.info : [ 145] gl-wifi-core>> (HTML) new session initâŚ
Sun Jun 16 06:30:46 2019 user.info : [ 243] gl-sdk>> session delete ⌠Token invalid!
Sun Jun 16 06:43:46 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:43:46 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:43:46 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:47 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:48 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:49 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:50 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:43:50 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:43:50 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:51 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:52 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:53 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:54 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:43:54 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:43:54 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:55 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:56 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:57 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:58 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:43:58 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:43:58 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:43:59 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:00 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:01 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:02 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:44:02 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:44:02 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:03 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:04 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:05 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:07 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:44:07 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:44:07 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:08 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:09 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:44:10 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:40 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:45:40 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:45:40 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:41 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:42 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:43 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:44 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:45:44 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:45:44 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:45 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:46 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:47 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:48 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:45:48 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:45:48 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:49 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:50 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:51 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:52 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:45:52 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:45:52 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:53 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:45:54 2019 daemon.notice hostapd: wlan0: AP-STA-POSSIBLE-PSK-MISMATCH 98:3b:8f:c7:e3:e5
Sun Jun 16 06:46:41 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: authenticated
Sun Jun 16 06:46:41 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 IEEE 802.11: associated (aid 2)
Sun Jun 16 06:46:41 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 98:3b:8f:c7:e3:e5
Sun Jun 16 06:46:41 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 RADIUS: starting accounting session BF307B324FA9D04D
Sun Jun 16 06:46:41 2019 daemon.info hostapd: wlan0: STA 98:3b:8f:c7:e3:e5 WPA: pairwise key handshake completed (RSN)
Sun Jun 16 06:46:44 2019 daemon.info dnsmasq-dhcp[2968]: DHCPDISCOVER(br-lan) 98:3b:8f:c7:e3:e5
Sun Jun 16 06:46:44 2019 daemon.info dnsmasq-dhcp[2968]: DHCPOFFER(br-lan) 192.168.8.138 98:3b:8f:c7:e3:e5
Sun Jun 16 06:46:44 2019 daemon.info dnsmasq-dhcp[2968]: DHCPREQUEST(br-lan) 192.168.8.138 98:3b:8f:c7:e3:e5
Sun Jun 16 06:46:44 2019 daemon.warn dnsmasq-dhcp[2968]: Ignoring domain ad001.siemens.net for DHCP host name md1u15uc
Sun Jun 16 06:46:44 2019 daemon.info dnsmasq-dhcp[2968]: DHCPACK(br-lan) 192.168.8.138 98:3b:8f:c7:e3:e5 md1u15uc
Sun Jun 16 07:21:46 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 07:21:46 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: disassociated
Sun Jun 16 07:21:47 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sun Jun 16 07:21:54 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 07:21:54 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 07:21:54 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 07:21:54 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 RADIUS: starting accounting session 83B1D9B53B482E26
Sun Jun 16 07:21:54 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 WPA: pairwise key handshake completed (RSN)
Sun Jun 16 07:21:54 2019 daemon.info dnsmasq-dhcp[2968]: DHCPDISCOVER(br-lan) ac:5f:3e:79:b8:89
Sun Jun 16 07:21:54 2019 daemon.info dnsmasq-dhcp[2968]: DHCPOFFER(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89
Sun Jun 16 07:21:54 2019 daemon.info dnsmasq-dhcp[2968]: DHCPREQUEST(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89
Sun Jun 16 07:21:54 2019 daemon.info dnsmasq-dhcp[2968]: DHCPACK(br-lan) 192.168.8.137 ac:5f:3e:79:b8:89 Samsung-Galaxy-S7
Sun Jun 16 07:22:04 2019 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 07:22:04 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: disassociated
Sun Jun 16 07:22:04 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: authenticated
Sun Jun 16 07:22:04 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 IEEE 802.11: associated (aid 1)
Sun Jun 16 07:22:04 2019 daemon.notice hostapd: wlan0: AP-STA-CONNECTED ac:5f:3e:79:b8:89
Sun Jun 16 07:22:04 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 RADIUS: starting accounting session 83B1D9B53B482E26
Sun Jun 16 07:22:04 2019 daemon.info hostapd: wlan0: STA ac:5f:3e:79:b8:89 WPA: pairwise key handshake completed (RSN)
I believe there are IP conflicts that might cause the issue. What is the IP within your LAN?
The default IP for a GLinet router is: 192.168.8.0/24 and the hotel network also seems to use 192.168.8.0/24 (?). If that is the case, change the IPs of your routerâs LAN interface (reconnect devices after that) should work then.
