How can I make the VPN Client connect by default
I’m using the OpenVPN client and it works fine.
How can I make the client automatically initiate a connect?
Thanks
Which client are you talking about? There should be an option on the client side of things to automatically connect.
It remembers the state, so if it was active before you shut down/unplugged the router it will be active when you re-start.
Thanks Eddie, yes the connected state. is maintained once rebooted - i discovered that also.
