How can I remove TOR on the slate AX??
I remember someone send a solution via email but I’ve misplaced it. If anyone can help I would appreciate it. Thanks guys!
Log into the GL.iNet Admin page go to plug-ins type: gl-sdk4-tor in search hit uninstall.
Thanks I tried this but it says that the software uninstall isn’t supported when I try to uninstall. I remember doing this before by running commands in openwrt
I believe you are referring the command line accessed by SSH
Command-line instructions
Manage packages with Opkg using command-line interface.
Command | Description |
opkg update |
Fetch a list of available packages from the OpenWrt package repository. |
opkg list |
Display a list of available packages and their descriptions. |
`opkg list | grep -e ` |
opkg install <packages> |
Install a package. |
opkg remove <packages> |
Uninstall a previously installed package. |
so it would be:
opkg remove tor (this should remove everything)
opkg remove tor-geoip(installed by default)
opkg remove gl-sdk4-tor(I think this is part of GL.iNet base files)
Brilliant yes you are right
I will try this it sounds right!
