hi,
the TF card is NTFS formatted, when insert the default mount point is /mnt/Microsoft basic data
the empty spaces makes hyperlinks terrible.
googled but cant find solution.
how to change that name? thanks
i am using brumeW, rom v3.105 thx
hi,
Is your TF card labelled as “Microsoft basic data”? If so, then try changing the label to remove the blanks.
If that does not work, then you can change the mount point via LuCI UI → System → Mount Points.
