How do I add a simple graph in to GUI?
I would like to add a graph that shows Upload and Download speeds via wan and via wifi in to main GUI so I don't have to switch to Luci every time. I would like to see the graph in Systems --> Overview tab.
Not a speed test.
Is there a plugin in can download and install from Plug-ins page from with in the routers GUI interface?
Thanks.
You can't.
The GL GUI can't be modified, unfortunately.
Thats a bummer. Can it be added to future firmware?
Cheers.
@bruce Maybe something for R&D
Something simple, that looks similar to CPU graph would be great.
Cheers.
