Greetings,
I spent months programming the router. It’s working perfect. Testing, QA…everthing.
I have to make 100 units of these…how do I can backup and create an image I can use to flash? OPENWRT , with Luci, Chaos Calmer
Thank you.
Greetings,
Thank you.
Don’t back up your configure and install in another router.
Compile your own firmware using the imagebuilder GitHub - gl-inet/imagebuilder-cc-ramips
You can put all of your configuration in “files” folder so that they are hard coded. Once you made the firmware working you will solve all your headache.
