I'm following this guide at the section If your public IP address is dynamic (link), which tells me to edit the endpoint on the configuration file, then apply it.
However, I don't see anywhere that I can upload a .conf file or edit it in place on the Admin Panel. This is what my Admin Panel looks like. My Admin Panel version is 4.6.11.
Hi, I don't have a public IP, which is why I'm going the AstroRelay route suggested earlier in the instructions. The instructions did say to replace the endpoint....
You need to export and download the profile to the client locally first, and use Notepad or import the WireGuard App to edit the 'endpoint', replace the Astrorelay address.
Now also can try the Zerotier, Tailscale, AstroWarp to create your private network.
