How i can using flint2 as exit node
Hello Guys. I want to use my flint2 as exit node without tailscape, but i can't select my router as exit node. Any solution for it? I don't want to use a Raspberry or mini PC how exit node, but if Is possibile i want to use directly my router. I Just modified with guide
Please explain "exit node" because you don't use tailscale. "exit node" is generally a concept for Tailscale.
