How to assign static ip to lan / wireless devices
I would like my IOT devices to have the same reserved lan ip; how do I do this please ? I have a spitz AX
Iā€™m not sure if this also works with the Spitz AX, but basically:
  1. open the web interface of the router
  2. open the network tab
  3. open the LAN tab
  4. enter the MAC address
However, this only works if the IOT device does not use randomized MAC addresses.
thank you that worked :slight_smile:
