Yes. 300K requests. I make more than 1 million, so…
Good service, but unfortunately too castrated for free. I will better buy something like Burume (Gl device too) and use it in LAN to make everything filter if hosts block will overload CPU.
admon
42
Nothing you can do about it.
slesar
43
300k per month should be enough. If you or someone use devices every days then yes you need to buy adguard VPN (cheaper way).
Another option buy better gl router for home. Or buy mini PC server.
I need only cellular one.
It is subscription… Of course no. I think I will run something on Burume. Maybe this will help
slesar
45
Have you try local domain "ru" in your router setting luci (network > dhcp and dns > general, local domain change "ru")
Alphax
46
I tried to block TLD by:
address=/*.ru/0.0.0.0
Rules in DNSMASQ and it is ok.
But OP should use RPi or something similar to block IPs. They are too heavy for regular router
I told above TLD blocked. The issue how to block direct (IP) access
