I just bought a Beryl and have set it up, but want to make sure I check in with the experts here on my settings before I bring this with me on my travels or use it with public WiFi. I don't want to use my Beryl without knowing it's not configured securely.
I set this up at a relative's place who is using an ISP-supplied router/modem. They're using the default username/password. Definitely a bad idea, but if a properly configured Beryl is connected to this network, are those devices secured?
I set the Beryl up in Repeater mode. Band selection is set to 5ghz. Any reason I should consider auto when all of my devices are modern and support 5ghz? Not only do I get better speed, but the shorter range could be a blessing in disguise in terms of security. I allow switching to other saved networks.
Under wireless, I disabled all the 2.4ghz networks and 5ghz guest WiFi. TX power is set to max. Security is set to WPA3-SAE. SSID visibility is set to show. What should WiFi mode, bandwidth, and channel be set to? For channel, I notice 132 (DFS) is the default.
Under VPN, I only use the client tab. I am using Proton VPN and used the Wireguard configuration from Proton. I uploaded them to the Beryl. It seems like I'm connected when there is a green light next to the VPN server. Is this right? If so, is there a way to set up a kill switch where the internet is blocked when the VPN connection is lost? My biggest worry with privacy and security is that I have no way of knowing if I'm always connected to the VPN. I'm afraid I might be spied upon with the VPN disconnected without me knowing. The only way to know is to always check the Beryl's GUI. I am used to using VPN on my Android as I see the VPN icon on the screen and that is proof I'm still connected. How do I address this? I also use TCP and is there a way to apply Proton's Stealth protocol? Is there a way to set up a split tunnel at the router level? Again, something that's easy to configure and use with the VPN on my phone.
Under applications and network storage, I have Samba enabled. I intend to attach a flash drive to the Beryl's USB port. How do I access any files like PDFs and movies from my iPhone, Google Pixel, and Samsung Galaxy S25 Ultra? Any other settings to turn on or off for performance, privacy, and security?
I have Adguard Home turned on and let it handle client requests.
I notice some DNS settings don't appear with Adguard Home on. Can that compromise my privacy and security? I currently have DNS Rebinding Attack Protection and Override DNS Settings of All Clients turned on. Allow Custom DNS to Override VPN DNS is off. I am using encrypted DNS, DNS over TLS, and Cloudflare. Is there any way to use these settings with Adguard Home on?
For Adguard Home, I'm assuming it's on when it's lighted green? Under DNS blocklists, I have Adguard DNS filter, AdAway Default Block, Hagezi Pro++ Block, Steven Black's List, 1Hosts (Lite), and OIST Blocklist Big turned on. Are there any redundancies? Any other block list I should have for maximum security and privacy?
Any other settings I should have on or off with Adguard Home? I don't know what else to consider.
I have changed the password under the system tab. I have also updated to the latest firmware. Once I get the hang of it, I'll consider flashing to OpenWRT instead of GL.iNet's own GUI on top of OpenWRT. I don't know how I should set up the toggle button and how you guys are setting it.
Really looking forward to hearing from you guys! I'm eager to learn. Thank you!
