Follow user case:
Follow working fine:
- Some PCs are unseeing VPN by gl router like AR-750s and FW 3.2 or so on.
- The PCs are connected to gl router by Ethernet.
How to configure the follow on gl router ?
One of the PCs which are connected also by Ethernet to the gl router, should use the VPN only use for one special adress, p.e. www.example.com For the rest of traffic of this PC should be not used the VPN. The IP, MAC and PC name are known of this PC.
Or one of the PCs which are connected also by Ethernet to the gl router, should dont use the VPN only for one special adress, p.e. www.example.com For the rest of traffic of this PC should be used the VPN. The IP, MAC and PC name are known of this PC.
Its possible to configure this by GUI ? And how to do ?
And how about the DNS on this case ? Are the DNS used by VPN for every traffic or one part of DNS by VPN and one part of DNS without to use the VPN ?
THX
