@alzhao Please allow me to change the topic name so that other users can find this topic. I want to change to:
How to connect Gl-E750 (MIDI) to PC using cable
Hello . The solution is to connect GL-E70 to PC with a CABLE (not WI-FI Repeator) so that you can see the MUDi interface to update the firmware or download the program you need.
You need to install firmware for LAN Adapter from the repository OpenWrt on Gl-E750
opkg update opkg list kmod-usb-net* You can see the available firmware opkg install kmod-usb-net-asix-ax88179 (my adapter is in the example) reboot
Also, if you are using a proprietary distribution like Ubuntu, you need to check if you have drivers with the command: apt-cache search firmware-realtek apt-cache show firmware-realtek
In this list you will find drivers
When you connect everything in the photo, let’s call it a New Year’s decorations))
Your PC will have a free LAN to which you connect your internet cable.
Check the network interface ip -c a
You will see a new interface, usually called enx….
If you use mac or windows (which is much worse than linux), then as a rule, installing lan adapter drivers is much easier.
