How to enable the 802.11r (Fast Roaming) for WiFi in Flint 3 (GL-BE9300)
Does this also work with a Flint 3e?
Yes — just ignore the 6GHz part.
Thank you for the clarification. Regarding the SSH code: can I freely choose the mobility domain or do I have to check something?
Yes, depends on the mobility domain of your network.
Mobility domain must be the same between network that roaming may occur to/from.
So if you were to have a 2.4GHz SSID and 5GHz SSID, you can use the same mobility domain.
But do not share mobility domain between the normal network and the guest network, as those are really different networks.
I have the same experience! When I set up 802.11r on 2.4 and 5 ghz these bands stops working. Only 6ghz continues to operate!
Here is my /etc/config/wireless :
config wifi-device 'wifi0'
	option type 'qcawificfg80211'
	option channel '1'
	option macaddr '94:83:c4:b0:9a:be'
	option hwmode '11beg'
	option disabled '0'
	option noscan '0'
	option country 'HU'
	option txpower '30'
	option random_bssid '1'
	option band '2g'
	option htmode 'HT20'
	option legacy_rates '0'
config wifi-iface 'wifi2g'
	option device 'wifi0'
	option network 'lan'
	option mode 'ap'
	option ssid 'TP-link MESH'
	option encryption 'psk2+ccmp'
	option macaddr '46:8A:5A:ED:E5:26'
	option factory_macaddr '94:83:c4:b0:9a:be'
	option key 'dummypassword:)'
	option wds '1'
	option isolate '0'
	option hidden '0'
	option ifname 'wlan0'
	option ieee80211k '1'
	option bss_transition '1'
	option sae '0'
	option no_beacon_rsnxe '1'
	option ft_over_ds '0'
	option ft_psk_generate_local '1'
	option mobility_domain '4f57'
	option wnm_sleep_mode '0'
	option wnm_sleep_mode_no_keys '1'
	option ieee80211r '0'
	option proxy_arp '0'
	option time_advertisement '2'
	option time_zone 'GMT0'
config wifi-device 'wifi1'
	option channel '36'
	option macaddr '94:83:c4:b0:9a:bf'
	option hwmode '11bea'
	option disabled '0'
	option country 'HU'
	option txpower '30'
	option band '5g'
	option htmode 'HT80'
	option channels '36,40,44,48'
config wifi-iface 'wifi5g'
	option device 'wifi1'
	option mode 'ap'
	option macaddr '62:BB:98:B3:A4:CE'
	option factory_macaddr '94:83:c4:b0:9a:bf'
	option wds '1'
	option isolate '0'
	option hidden '0'
	option ifname 'wlan1'
	option sae '0'
config wifi-device 'wifi2'
	option channel 'auto'
	option macaddr '94:83:c4:b0:9a:c0'
	option disabled '0'
	option country 'HU'
	option txpower '30'
	option band '6g'
	option htmode 'HT320'
	option channels '5,21,37,53'
	option chan_6g_only_psc '1'
	option require_mode 'ax'
config wifi-iface 'wifi6g'
	option device 'wifi2'
	option mode 'ap'
	option encryption 'ccmp'
	option macaddr 'DE:F1:7E:D8:5B:07'
	option factory_macaddr '94:83:c4:b0:9a:c0'
	option sae_pwe '1'
	option wds '1'
	option isolate '0'
	option hidden '0'
	option ifname 'wlan2'
	option bss_transition '0'
	option sae '1'
	option acs_6g_only_psc '1'
	option no_beacon_rsnxe '0'
	option disabled '0'
config wifi-iface 'guest2g'
	option network 'guest'
	option mode 'ap'
	option ifname 'wlan01'
	option encryption 'none'
	option key 'goodlife'
	option ssid 'WIFI-SN2001007737'
	option macaddr '0E:D7:C6:7C:43:DA'
	option factory_macaddr '96:83:c4:b0:9a:be'
	option guest '1'
	option disabled '1'
	option wds '1'
	option isolate '1'
	option hidden '0'
	option sae '0'
config wifi-iface 'wlanmld2g'
	option mode 'ap'
	option macaddr 'A6:C8:7C:14:CA:68'
	option factory_macaddr '94:83:c4:b0:9a:c2'
	option ssid 'GL-BE9300-abb-MLO'
	option sae '1'
	option wds '1'
	option isolate '0'
	option hidden '0'
	option ifname 'wlan02'
	option disabled '1'
	option mld 'mld0'
config wifi-iface 'wlanmldguest2g'
	option mode 'ap'
	option ifname 'wlan03'
	option sae '1'
	option ssid 'GL-BE9300-abb-MLO-Guest'
	option macaddr '16:82:96:15:7A:3F'
	option factory_macaddr '96:83:c4:b0:9a:c2'
	option guest '1'
	option disabled '1'
	option wds '1'
	option isolate '1'
	option hidden '0'
	option mld 'mld1'
config wifi-iface 'guest5g'
	option mode 'ap'
	option ifname 'wlan11'
	option ssid 'GL-BE9300-abb-5G-Guest'
	option macaddr 'A6:C8:A5:1A:4E:63'
	option factory_macaddr '96:83:c4:b0:9a:bf'
	option guest '1'
	option disabled '1'
	option wds '1'
	option isolate '1'
	option hidden '0'
config wifi-iface 'wlanmld5g'
	option mode 'ap'
	option macaddr 'B6:8F:73:CD:D4:54'
	option factory_macaddr '94:83:c4:b0:9a:c3'
	option sae '1'
	option wds '1'
	option isolate '0'
	option hidden '0'
	option ifname 'wlan12'
	option disabled '1'
	option mld 'mld0'
config wifi-iface 'wlanmldguest5g'
	option mode 'ap'
	option ifname 'wlan13'
	option sae '1'
	option macaddr '3E:C0:DB:D2:B5:70'
	option factory_macaddr '96:83:c4:b0:9a:c3'
	option guest '1'
	option disabled '1'
	option wds '1'
	option isolate '1'
	option hidden '0'
	option mld 'mld1'
config wifi-iface 'guest6g'
	option mode 'ap'
	option ifname 'wlan21'
	option sae_pwe '1'
	option ssid 'GL-BE9300-abb-6G-Guest'
	option macaddr 'DE:F1:7E:D8:5B:08'
	option factory_macaddr '94:83:c4:b0:9a:c1'
	option guest '1'
	option disabled '1'
	option wds '1'
	option isolate '1'
	option hidden '0'
	option sae '1'
config wifi-iface 'wlanmld6g'
	option mode 'ap'
	option macaddr 'DE:F1:7E:D8:5B:09'
	option factory_macaddr '94:83:c4:b0:9a:c4'
	option sae '1'
	option wds '1'
	option isolate '0'
	option hidden '0'
	option ifname 'wlan22'
	option disabled '1'
	option mld 'mld0'
config wifi-iface 'wlanmldguest6g'
	option mode 'ap'
	option ifname 'wlan23'
	option sae '1'
	option macaddr 'DE:F1:7E:D8:5B:0a'
	option factory_macaddr '94:83:c4:b0:9a:c5'
	option guest '1'
	option disabled '1'
	option wds '1'
	option isolate '1'
	option hidden '0'
	option mld 'mld1'
config wifi-iface 'sta'
	option mode 'sta'
	option ifname 'sta0'
	option network 'wwan'
	option ssid 'WIFI-SN2001007736'
	option bssid 'b6:e6:2d:64:a7:8e'
	option macaddr '92:83:c4:b0:9a:c0'
	option disabled '1'
Also some logread when 802.11r was turned on:
Thu Mar  5 21:36:58 2026 kern.err kernel: [556146.419113] wlan: [25946:I:ANY] osif_pltfrm_create_ppe_vp_802_3_redir_vap:
Thu Mar  5 21:36:58 2026 kern.err kernel: [556146.419113] dev:00000000890ff4f4, dev->name:wlan1 osnetdev:00000000b844703a, allocated VP # 65
Thu Mar  5 21:36:58 2026 kern.err kernel: [556146.432325] wlan: [25946:I:RPTR] RPTR vdev flags:0 pdev flags:0 vdev_id:0 pdev_id:0
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.028634] wlan: [28708:I:ANY] wlan_scan_update_channel_list: num_chan: 24
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.028812] wlan: [28708:I:ANY] number of channels: 2G = 0 5G = 0, 6G = 24
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.034803] wlan: [28708:I:ANY] wlan_cfg80211_set_country: wlan_cfg80211_set_country: Country: HU ret: 0
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.100969] wlan: [28716:E:ANY] ol_ath_set_config_param: rpt_max_phy is already enabled!
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.328698] wlan: [28759:I:ANY] ol_ath_set_config_param: set TXBF_SND_PERIOD: val 100 stat 0
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.412469] wlan: [0:I:RPTR] RPTR disconnect_timeout:10
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.440045] wlan: [0:I:RPTR] RPTR reconfiguration_timeout:60
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.584307] wlan: [28815:I:MBSSIE] osif_mbssid_sanity_check: mbssid_sanity_ok: YES
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.584335] wlan: [28815:I:ANY] osifp_create_wlan_vap: No cloning
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.590954] wlan: [28815:I:ANY] osifp_create_wlan_vap: VDEV Create de:f1:7e:d8:5b:07
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.597011] wlan: [28815:I:ANY] osifp_create_wlan_vap: mlo_mbssid disabled in lower band radios
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.605151] wlan: [28815:I:ANY] wlan_vap_create: devhandle=0x00000000987c2bcf, opmode=IEEE80211_M_HOSTAP, flags=0x0
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.615484] wlan: [28815:E:ANY] ol_ath_vdev_set_intra_bss: vdev is NULL!
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.627429] wlan: [28815:I:ANY] ol_ath_vap_set_param: VDEV params:EHT su_bfee:1|su_bfer:1|mu_bfee:0|mu_bfer:1|dl_ofdma:1|ul_ofdma:1|ulmumimo:1|dl_muofdma_bfer:1|dl_muofdma_mumimo:0|ul_muofdma_mumimo:0
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.634178] wlan: [28815:I:ANY] ol_ath_vap_set_param: eht_mu_bf_mode=0xfb
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.652082] wlan: [28815:I:ANY] ieee80211_add_vdev_ids: vdev_id:1 pos:0
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.658858] wlan: [28815:E:ANY] wlan_create_attach_vdev_rawsim_ctxt: simulation module not registerd
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.688615] wlan: [28815:I:ANY] osif_pltfrm_create_ppe_vp: vp user type: ds vpai.core_mask: 7 target type: 32 vpnum: 66 icp_flags: 400000
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.688649] wlan: [28815:I:ANY] osif_pltfrm_create_ppe_vp_802_3_redir_vap:
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.688649] dev:0000000085446e93, dev->name:wlan2 osnetdev:000000004717c019, allocated VP # 66
Thu Mar  5 21:37:03 2026 kern.err kernel: [556151.701931] wlan: [28815:I:RPTR] RPTR vdev flags:0 pdev flags:0 vdev_id:1 pdev_id:1
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.722129] br-lan: port 2(wlan0) entered blocking state
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.722152] br-lan: port 2(wlan0) entered disabled state
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.727130] device wlan0 entered promiscuous mode
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.732835] device wlan0 left promiscuous mode
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.736973] br-lan: port 2(wlan0) entered disabled state
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.799209] 8021q: adding VLAN 0 to HW filter on device wlan0
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.799688] br-lan: port 2(wlan0) entered blocking state
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.804096] br-lan: port 2(wlan0) entered disabled state
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.810279] device wlan0 entered promiscuous mode
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.815182] br-lan: port 2(wlan0) entered blocking state
Thu Mar  5 21:37:05 2026 kern.info kernel: [556153.819513] br-lan: port 2(wlan0) entered forwarding state
Thu Mar  5 21:37:05 2026 daemon.notice netifd: Network device 'wlan0' link is up
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.661220] br-lan: port 3(wlan1) entered blocking state
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.661243] br-lan: port 3(wlan1) entered disabled state
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.666319] device wlan1 entered promiscuous mode
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.672103] device wlan1 left promiscuous mode
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.676036] br-lan: port 3(wlan1) entered disabled state
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.769358] 8021q: adding VLAN 0 to HW filter on device wlan1
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.769753] br-lan: port 3(wlan1) entered blocking state
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.774196] br-lan: port 3(wlan1) entered disabled state
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.780125] device wlan1 entered promiscuous mode
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.785193] br-lan: port 3(wlan1) entered blocking state
Thu Mar  5 21:37:06 2026 kern.info kernel: [556154.789659] br-lan: port 3(wlan1) entered forwarding state
Thu Mar  5 21:37:06 2026 daemon.notice netifd: Network device 'wlan1' link is up
Thu Mar  5 21:37:07 2026 kern.info kernel: [556155.459022] 8021q: adding VLAN 0 to HW filter on device wlan2
Thu Mar  5 21:37:07 2026 kern.info kernel: [556155.459619] br-lan: port 4(wlan2) entered blocking state
Thu Mar  5 21:37:07 2026 kern.info kernel: [556155.463787] br-lan: port 4(wlan2) entered disabled state
Thu Mar  5 21:37:07 2026 kern.info kernel: [556155.469710] device wlan2 entered promiscuous mode
Thu Mar  5 21:37:07 2026 kern.info kernel: [556155.474723] br-lan: port 4(wlan2) entered blocking state
Thu Mar  5 21:37:07 2026 kern.info kernel: [556155.479302] br-lan: port 4(wlan2) entered forwarding state
Thu Mar  5 21:37:07 2026 kern.err kernel: [556155.487704] wlan: [10566:I:ANY] wlan_cfg80211_do_acs: vap-1(wlan2):ACS Params
Thu Mar  5 21:37:07 2026 kern.err kernel: [556155.490173] wlan: [10566:I:ANY] wlan_cfg80211_do_acs: ht_enabled:1|ht40_enabled:0|vht_enabled:1|hw_mode:43|chwidth:320|
Thu Mar  5 21:37:07 2026 kern.err kernel: [556155.497471] wlan: [10566:I:ANY] wlan_mbss_start_acs: ACS Arg: 000000004908ff42
Thu Mar  5 21:37:07 2026 daemon.notice netifd: Network device 'wlan2' link is up
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.686544] SAWF Telemetry: sawf_ctx->mov_avg.packet 1000
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.686549] SAWF Telemetry: sawf_ctx->mov_avg.window 10
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.686569] SAWF Telemetry: sawf_ctx->sla_param.num_packets10000
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.691305] SAWF Telemetry: sawf_ctx->sla_param.time_secs10
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.817984] SAWF Telemetry: Service ID: 126
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.818006] SAWF Telemetry: cfg->min_thruput_rate 95
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.822738] SAWF Telemetry: cfg->max_thruput_rate 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.826967] SAWF Telemetry: cfg->burst_size 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.831904] SAWF Telemetry: cfg->service_interval 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.836929] SAWF Telemetry: cfg->delay_bound 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.841191] SAWF Telemetry: cfg->msdu_ttl 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.846304] SAWF Telemetry: cfg->msdu_rate_loss 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.865175] SAWF Telemetry: Service ID: 127
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.865196] SAWF Telemetry: cfg->min_thruput_rate 95
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.868879] SAWF Telemetry: cfg->max_thruput_rate 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.873271] SAWF Telemetry: cfg->burst_size 0
Thu Mar  5 21:37:08 2026 kern.debug kernel: [556156.878219] SAWF Telemetry: cfg->service_interval 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.883262] SAWF Telemetry: cfg->delay_bound 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.887506] SAWF Telemetry: cfg->msdu_ttl 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.892638] SAWF Telemetry: cfg->msdu_rate_loss 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.911408] SAWF Telemetry: Service ID: 128
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.911427] SAWF Telemetry: cfg->min_thruput_rate 95
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.915074] SAWF Telemetry: cfg->max_thruput_rate 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.919544] SAWF Telemetry: cfg->burst_size 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.924464] SAWF Telemetry: cfg->service_interval 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.929493] SAWF Telemetry: cfg->delay_bound 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.933738] SAWF Telemetry: cfg->msdu_ttl 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.938867] SAWF Telemetry: cfg->msdu_rate_loss 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.965126] SAWF Telemetry: type 0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.965146] SAWF Telemetry: detect->min_thruput_rate:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.968839] SAWF Telemetry: detect->max_thruput_rate:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.972179] SAWF Telemetry: detect->burst_size:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.977388] SAWF Telemetry: detect->service_interval:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.982607] SAWF Telemetry: detect->delay_bound:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.987457] SAWF Telemetry: detect->msdu_ttl:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556156.992508] SAWF Telemetry: detect->msdu_rate_loss:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.001152] SAWF Telemetry: type 1
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.001782] SAWF Telemetry: detect->min_thruput_rate:1
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.006986] SAWF Telemetry: detect->max_thruput_rate:1
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.010664] SAWF Telemetry: detect->burst_size:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.015519] SAWF Telemetry: detect->service_interval:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.020925] SAWF Telemetry: detect->delay_bound:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.025645] SAWF Telemetry: detect->msdu_ttl:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.030712] SAWF Telemetry: detect->msdu_rate_loss:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.039596] SAWF Telemetry: type 2
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.039891] SAWF Telemetry: detect->min_thruput_rate:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.045096] SAWF Telemetry: detect->max_thruput_rate:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.048489] SAWF Telemetry: detect->burst_size:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.053608] SAWF Telemetry: detect->service_interval:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.058855] SAWF Telemetry: detect->delay_bound:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.063676] SAWF Telemetry: detect->msdu_ttl:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.068736] SAWF Telemetry: detect->msdu_rate_loss:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.080467] SAWF Telemetry: type 3
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.080490] SAWF Telemetry: detect->min_thruput_rate:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.089785] SAWF Telemetry: detect->max_thruput_rate:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.089805] SAWF Telemetry: detect->burst_size:1
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.093878] SAWF Telemetry: detect->service_interval:1
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.099163] SAWF Telemetry: detect->delay_bound:0
Thu Mar  5 21:37:09 2026 kern.debug kernel: [556157.104968] SAWF Telemetry: detect->msdu_ttl:1
Thu Mar  5 21:37:12 2026 kern.debug kernel: [556157.109090] SAWF Telemetry: detect->msdu_rate_loss:1
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.668675] wlan: [0:I:ANY] ieee80211_acs_post_event: [EXT] Channel number: 00000000aad3a677
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.672710] wlan: [0:I:ANY] wlan_mbss_done_acs: Channel: 00000000aad3a677
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.681310] wlan: [0:I:ANY] vap-1(wlan2): ACS result PCH 37 freq 6135, SCH 0 freq 0, hw_mode 2 chwidth 320, vht_seg0 47 freq 6185, vht_seg1 31 freq 6105 puncture pattern 0 LinkID: 0
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.688083] wlan: [21027:I:ANY] ieee80211_acs_scan_evhandler: [EXT] lock held duration (19ms)
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.722330] wlan: [10566:I:ANY] wlan_cfg80211_start_ap: Start wlan2 psoc:1 vdev:1
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.722382] wlan: [10566:I:ANY] DES SSID SET=TP-link MESH
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.728940] wlan: [10566:I:ANY] desired hw mode: 43
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.734407] wlan: [10566:I:ANY] wlan_cfg80211_chan_to_phymode: band:3 width: 13 channel_cfreq: 6135 center_freq1: 6105 chandef.center_freq2: 0 flags: 512
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.739513] wlan: [10566:I:ANY] HT Support:0000000000000000 VHT Support:0000000000000000 HE Support:0000000003528cb3
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.753117] wlan: [10566:I:ANY] cfg80211_chan_to_phymode_6g: Max supported wireless mode: 4
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.763712] wlan: [10566:I:ANY] Phymode: 43
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.772617] wlan: [26130:I:ANY] number of channels: 2G = 0 5G = 0, 6G = 24
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.778725] wlan: [10566:I:ANY] wlan_scan_update_channel_list: num_chan: 24
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.784889] wlan: [10566:I:ANY] ieee80211_ucfg_set_freq_internal:
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.784889]  Channel is configured already!!
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.792154] wlan: [8706:I:ANY] number of channels: 2G = 0 5G = 0, 6G = 24
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.799265] wlan: [10566:I:ANY] wlan_scan_update_channel_list: num_chan: 24
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.809637] wlan: [10566:I:MBSSIE] wlan_cfg80211_start_ap: Set tx-vap wlan2: vdev_id:1
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.816944] wlan: [10566:W:MLO_MGR] wlan_mlme_start_ap_vdev: Allowing 11be non-MLO operation as per INI configuration
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.824561] wlan: [10566:E:ANY] wlan_cfg80211_start_ap: vap1:HT CAP setting failed
Thu Mar  5 21:37:12 2026 kern.err kernel: [556160.835080] wlan: [10566:E:ANY] wlan_cfg80211_start_ap: vap1:VHT CAP setting failed
Thu Mar  5 21:37:12 2026 user.info usteer: Creating local node hostapd.wlan2
Thu Mar  5 21:37:12 2026 user.info usteer: Found nl80211 phy on wdev hostapd.wlan2, ssid=TP-link MESH
Thu Mar  5 21:37:12 2026 user.info usteer: Connecting to local node hostapd.wlan2
Thu Mar  5 21:37:13 2026 kern.err kernel: [556160.972632] wlan: [0:I:CMN_MLME] mlme_ext_vap_up: Enabling FILS in 6Ghz VAP: 1
Thu Mar  5 21:37:13 2026 kern.err kernel: [556160.972775] wlan: [0:E:ANY] mlme_ext_vap_up: VAP (wlan2) de:f1:7e:d8:5b:07 is up, vdev_id:1 pdev_id:1 psoc_id:1
Thu Mar  5 21:37:13 2026 daemon.info hostapd: wlan2: IEEE 802.11 driver had channel switch: iface->freq=6135, freq=6135, ht=1, vht_ch=0x0, he_ch=0x0, eht_ch=0x0, offset=-1, width=10 (320 MHz), cf1=6105, cf2=0, puncturing_bitmap=0x0
I’m on latest snapshot firmware.
The wireless parameters for the 2.4 GHz and 5 GHz bands are abnormal, apart from 802.11r,
        option ieee80211r '1'
        option ft_over_ds '1'
        option nasid 'ap1'
There were some extra parameters that might cause the wireless drive to fail to recognize it:
And brings the drive initialization may have failed.
6GHz configuration you pasted has no 802.11r-related parameters.
Please reset the router and use the uci command to enable/configure 802.11r.
Enable 802.11r for 6GHz WiFi:
uci set wireless.wifi6g.ieee80211r='1'
uci set wireless.wifi6g.mobility_domain='4f57'
uci set wireless.wifi6g.ft_over_ds='1'
uci set wireless.wifi6g.nasid='ap1'
uci commit wireless
/etc/init.d/network restart
Enable 802.11r for 5GHz WiFi:
uci set wireless.wifi5g.ieee80211r='1'
uci set wireless.wifi5g.mobility_domain='4f57'
uci set wireless.wifi5g.ft_over_ds='1'
uci set wireless.wifi5g.nasid='ap1'
uci commit wireless
ubus call network restart
Enable 802.11r for 2.4GHz WiFi:
uci set wireless.wifi2g.ieee80211r='1'
uci set wireless.wifi2g.mobility_domain='4f57'
uci set wireless.wifi2g.ft_over_ds='1'
uci set wireless.wifi2g.nasid='ap1'
uci commit wireless
Thank you, if it helps anybody the issue was the no_beacon_rsnxe being present in the config (and was set to 1). Deleting it solved the issue. Other options were perfectly fine.
If I have 3 router Flint 3, I see that the value of Mobility Domain should be the same in all the routers and bands. But what about the NAS ID? Should be different on each router but the same in the 3 bands of the same router?
Thanks.
The NAS ID string can use the router's MAC address (without the colons : ).
Does it work with Version 4.9.0. ?
Oddly enough I was messing with my flint 2 and saw this same WLAN roaming setting with the 802.11r Fast Transition… I know the commands say its just for the flint 3, but why not the flint 2?
I think v4.9 will still work since there is no Mesh function yet.
The proprietary (closed-source) wireless driver of the Flint 2 lacks support for 802.11r, supporting only 802.11k and 802.11v.
If you require 802.11r for Flint2, you can install the op24 firmware.
Does this also mean for the low level iw command?
Maybe one can still enable it with wpa_supplicant, then only luci has a issue.
Wireless driver of the closed source is not very clear.
Flint2 supports 802.11r in op24 firmware, please try this.
