It seemed like that in the Repeater just can not scan the hidden wifi, is that right?
Could I add a hidden wifi by input wifi ssid?
i found the way to connect to the hidden wifi in luci, but i can not delete this topic.
I think this was discussed just a few days back but it would be helpful if you could post the fix again or the link that helped you solve it!
