How to obtain technical assistance
Hello, I recently bought a GL-AX1800 router, and I have a lot of problems. How to obtain technical assistance, in order to have an operational router? I constantly have mistakes in the log file that I can’t solve.
THANKS
If possible you can also post the error message here
Hello here are errors messages
System Log
[code]
System Log
Sun Oct 15 23:59:01 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Sun Oct 15 23:59:01 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Sun Oct 15 23:59:01 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Sun Oct 15 23:59:01 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Sun Oct 15 23:59:03 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Sun Oct 15 23:59:04 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Sun Oct 15 23:59:04 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Sun Oct 15 23:59:04 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:08:56 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 70/0
Mon Oct 16 00:08:58 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 70/0
Mon Oct 16 00:09:02 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:09:02 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:09:02 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:09:02 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:09:04 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:09:05 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:09:05 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:09:05 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:18:57 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 71/0
Mon Oct 16 00:18:59 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 71/0
Mon Oct 16 00:19:03 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:19:03 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:19:03 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:19:03 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:19:06 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:19:06 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:19:06 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:19:06 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:28:58 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 72/0
Mon Oct 16 00:29:00 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 72/0
Mon Oct 16 00:29:04 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:29:05 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:29:05 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:29:05 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:29:07 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:29:07 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:29:07 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:29:07 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:38:59 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 73/0
Mon Oct 16 00:39:01 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 73/0
Mon Oct 16 00:39:06 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:39:06 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:39:06 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:39:06 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:39:08 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:39:08 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:39:08 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:39:08 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:49:00 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 74/0
Mon Oct 16 00:49:03 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 74/0
Mon Oct 16 00:49:07 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:49:07 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:49:07 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:49:07 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:49:09 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:49:09 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:49:09 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:49:09 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:59:01 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 75/0
Mon Oct 16 00:59:04 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 75/0
Mon Oct 16 00:59:08 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:59:08 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:59:08 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:59:08 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 00:59:10 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 00:59:10 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 00:59:10 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 00:59:10 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 01:09:03 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 76/0
Mon Oct 16 01:09:05 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 76/0
Mon Oct 16 01:09:09 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 01:09:10 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 01:09:10 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 01:09:10 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 01:09:11 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 01:09:11 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 01:09:11 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 01:09:11 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 01:13:04 2023 daemon.info hostapd: wlan1: STA bc:8c:cd:98:34:5d IEEE 802.11: authenticated
Mon Oct 16 01:13:04 2023 daemon.info hostapd: wlan1: STA bc:8c:cd:98:34:5d IEEE 802.11: associated (aid 2)
Mon Oct 16 01:13:04 2023 daemon.notice hostapd: wlan1: AP-STA-CONNECTED bc:8c:cd:98:34:5d 0 0
Mon Oct 16 01:13:04 2023 daemon.info hostapd: wlan1: STA bc:8c:cd:98:34:5d RADIUS: starting accounting session 9783345B5E4F8427
Mon Oct 16 01:13:04 2023 daemon.info hostapd: wlan1: STA bc:8c:cd:98:34:5d WPA: pairwise key handshake completed (RSN)
Mon Oct 16 01:14:33 2023 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED bc:8c:cd:98:34:5d 0 0
Mon Oct 16 01:14:33 2023 daemon.info hostapd: wlan1: STA bc:8c:cd:98:34:5d IEEE 802.11: disassociated
Mon Oct 16 01:19:04 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 77/0
Mon Oct 16 01:19:06 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 77/0
Mon Oct 16 01:19:11 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 01:19:11 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 01:19:11 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 01:19:11 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 01:19:12 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
Mon Oct 16 01:19:13 2023 daemon.info dnsmasq[26997]: read /etc/hosts - 4 addresses
Mon Oct 16 01:19:13 2023 daemon.err dnsmasq[26997]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
Mon Oct 16 01:19:13 2023 daemon.info dnsmasq-dhcp[26997]: read /etc/ethers - 0 addresses
Mon Oct 16 01:29:05 2023 user.warn ddns-scripts[12491]: bgwen: Updating IP at DDNS provider failed - starting retry 78/0
Mon Oct 16 01:29:07 2023 user.warn ddns-scripts[12175]: bgwen2: Updating IP at DDNS provider failed - starting retry 78/0
Mon Oct 16 01:29:12 2023 user.notice dnsmasq: found already running DHCP-server on interface 'eth0' refusing to start, use 'option force 1' to override
https://transfert.free.fr/kPPqpLu
Thank you
Have you changed the network configuration file?
cat /etc/config/network
My Flint GL AX1800 is connected to an internet box (192.168.10.1) I put the address of the router in IP Static (192.168.10.2) and I changed the address of the Flint IP 192.168.8.1 by 192.168.1.1. My private network began at 192,168.2 to 192,168.33
network.zip (737 Bytes)
Can you get the internet without setting a static IP?
There should not be any DHCP server running on ‘eth0’, which is the WAN Ethernet port connect to your ISP router.
Thank you, but how do I do it to deactivate ‘DHCP’ on ‘eth0’?
Log into LuCI, then go to Network → Interfaces → WAN → Edit → DHCP Server and click on Ignore interface. Make sure to Save & Apply afterwards.
Thank you WCS2228 DHCP set. On the other hand, I always have these lines of errors which return constantly in System Log. I think of a permission problem on the file dhcp.cfg01411c .
daemon.info dnsmasq[18106]: read /etc/hosts - 4 addresses
daemon.err dnsmasq[18106]: failed to load names from /tmp/hosts/dhcp.cfg01411c: Permission denied
daemon.info dnsmasq-dhcp[18106]: read /etc/ethers - 0 addresses
So I launched this order chmod 644 /tmp/hosts/dhcp.cfg01411c But unfortunately still errors .
My no-IP dyndns this updates and I still have these mistakes
user.warn ddns-scripts[15483]: bgwen: Updating IP at DDNS provider failed - starting retry 9/0
user.warn ddns-scripts[15767]: bgwen2: Updating IP at DDNS provider failed - starting retry 9/0
Do you have an idea ? THANKS
I do not think that the /tmp/hosts/dhcp.cfg01411c is very important. It may be due to a firmware bug.
The no-ip.com DDNS failure may be due to incorrectly-entered username/password and/or incorrect configuration.
Hello and thank you wcs 2228 I found the solution there is a bug in the firmware. I found the solution, I edited Dnsmasq and add this line
mv -f $HOSTFILE_TMP $HOSTFILE
I found the solution on this page
https://github.com/openwrt/openwrt/issues/7844
I hope that the next update the line will not jump.
