Hi all,
I'm a network engineer and need you support re my Opal GL-SFT1200 access point.
I want to use my wifi access point to wirelessly connect to a switch in another room and access the client connected to the switch remotely.
The switch and all clients are on network 10.100.87.65 255.255.255.192. I want to set a static IP address on access point WAN interface from the same range (say 10.100.87.113) and connect it to the switch. Then I will hook up my laptop wirelessly to the access point. (it will get an IP address like 192.168.8.102 from the DHCP)
I tried everything I know and found online to be able to ping the clients on the switch by my laptop but never successful. Like disabling NAT via SSH command line or bridging WLAN and WAN interface of the access point. nothing worked.
please not, I don't need internet access, just need to access another network with a specific IP range, via the wireless connection of the access point.
Really appreciate your support! ![]()
