rob_87
March 15, 2017, 7:19pm
yesterday i got my AR300m.
I tried to upload my Ovpn files, packed in a zip-File, but the router is still talking “need ca, key, crl and cert”. but it is all in the Zip-file.
Look:
https://youtu.be/repiDE4z8_U
From Pc to PC it’s working fine…
where is my mistake?
Thanks ROB
A strange situation, but you can add each file in the same way not in the archive. I was going through a similar problem, most likely after unpacking the archive, the real paths to the files and the automatically written links to the .ovpn do not match …
Import config algoritm incorrect.
alzhao
March 16, 2017, 10:19am
3
Is the firmware v2.25? If not, please upgrade.
From your video, I think you are doing it correctly.
I am not sure if @Passter is right about this. But if my eyes don’t cheat me the paths should be fine.
If you can you can send the zip to me so that I have a check.
You can also embed the ca, cert and key in the ovpn file, using the following format, so you can just upload one file, not zip.
<ca>
here is the content of the ca file
</ca>
<cert>
</cert>
<key>
</key>
rob_87
March 18, 2017, 12:41am
4
I tried it,
do i have also to copie the " -----BEGIN CERTIFICATE-----" part?
Or just the letter combination?
Thanks.
Including doesn’t help.
rob_87
March 19, 2017, 6:28pm
5
i success (i think).The router say connected.
My mistake was, that i had left the lines “key ***.key Cert ***.cert…” in the OPVN-File.
Delete the three lines and said connected.
Thanks <!-- .bbp-reply-author –> alzhao.
Next question: What should i do so that the VPN-Server can see the Client via ping. but I think I open a new Topic.
alzhao
March 19, 2017, 6:48pm
6
you want to ping the client (the router) from the server, right? or
You want to ping the clients connected to the router from the vpn server?
The router has a firewall and disables all input traffic. You need to allow input and forward in the router’s firewall.
