I want to convert the usb port to ethernet port…
You clould refer ‘gadget’.
From where can I found ‘gadget’?
There is no driver as “kmod-usb-gadget”
What is the model of your device?
GL-MT300N-V2 is my model, My aim is to use the USB port as Ethernet Port.
Is it possible to convert the USB port to Ethernet adapter port? If possible please guide me…
I’m sorry that it is not supported by offical firmware.So you need to compile source code to achieve.
I had changed the official firmware. Now i used OpenWrt firmware on it.
