Hqos(Hardware Qos) on my Flin2
Hi!
I noticed that among the files in my router Flint2 configuration there is mtkhnat,inside I read Hqos. I try to activate, my configuration
config global “global”
option enable “1”
option hqos “1”
option txq_num '16'
option scheduling “sp”
option sch0_bw '800000'
option sch1_bw “150000”
option actype “2” I get shaping with software offloading active, now I wonder if anyone knows if this type of Hqos is compatible with dscp markings. From what I have seen in firewall.user, it is possible to mark dscp with iptable, but I do not think they are compatible with it, only with sqm. I would like to know if anyone knows anything more.
Best regards
pesa1234’s openwrt mt6000 build messed with this: MT6000 custom build with LuCi and some optimization - kernel 6.12.x - #1530 by Nit3H8wk - Community Builds, Projects & Packages - OpenWrt Forum
@glinet Implementing hqos would be greatly appreciated.
MTK HQOS is typically used with luci-app-eqos-mtk.
Based on this app's scripts, it should be compatible with iptables DSCP.
You can refer to its source code:
