HTTP Port (80) Loopback
I have port 80 forwarded to a computer on my network and it works accessing from outside the network; but when I attempt to access from within my network it brings up the web interface to the GL-INET instead.
I don’t see a “loopback” option, so hoping someone has some guidance on this.
B
How about just change port 80 to others e.g. 8080.
The port config is in /etc/lighttpd/lighttpd/conf
I Should have clarified, it does it with any port (works from outside network but does not loopback). Port 80 is just the one I need, and it will go to the router’s webui rather than loopback, while other ports just don’t work (presumably because they are being directed to the router which doesn’t have those ports open).
B
