Huawei E3276 on GL-AR300M
I’m trying to get my 4G stick to work on my Gli router. An older E180 stick is recognised without problem, but the E3276 not. It’s just recognised as a mass storage device:
Sun Apr 16 15:00:16 2017 kern.info kernel: [ 380.230000] usb 1-1: USB disconnect, device number 2
Sun Apr 16 15:00:32 2017 kern.info kernel: [ 396.000000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sun Apr 16 15:00:32 2017 kern.info kernel: [ 396.190000] usb-storage 1-1:1.0: USB Mass Storage device detected
Sun Apr 16 15:00:32 2017 kern.info kernel: [ 396.210000] scsi host2: usb-storage 1-1:1.0
Sun Apr 16 15:00:32 2017 kern.info kernel: [ 396.210000] usb-storage 1-1:1.1: USB Mass Storage device detected
Sun Apr 16 15:00:32 2017 kern.info kernel: [ 396.220000] scsi host3: usb-storage 1-1:1.1
Sun Apr 16 15:00:33 2017 kern.notice kernel: [ 397.210000] scsi 2:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Sun Apr 16 15:00:33 2017 kern.notice kernel: [ 397.220000] scsi 3:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Sun Apr 16 15:00:33 2017 kern.notice kernel: [ 397.230000] sd 3:0:0:0: [sda] Attached SCSI removable disk
Is there anything I can check? Anything I have to install? Does this stick even work on a GLi?
thanks a log
simon
can you using “ifconfig -a” to see if this is a Hilink model and it will create a network interface?
If it is you can set up in the tethering tab.
I checked the internet but seems there is different models of E3276. E3276 should be supported from several years ago but you model seems not.
had a few looks around. ifconfig -a gave the following:
br-lan Link encap:Ethernet HWaddr E4:95:6E:40:B4:D3
inet addr:10.254.254.1 Bcast:10.254.254.255 Mask:255.255.255.0
inet6 addr: fde7:1dbd:2019::1%2/60 Scope:Global
inet6 addr: fe80::e695:6eff:fe40:b4d3%eth0/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3747 errors:0 dropped:0 overruns:0 frame:0
TX packets:5636 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:570618 (557.2 KiB) TX bytes:2962402 (2.8 MiB)
eth0 Link encap:Ethernet HWaddr E4:95:6E:40:B4:D3
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:4
eth1 Link encap:Ethernet HWaddr E4:95:6E:40:B4:D3
Interrupt:5
gre0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-44-00-00-00-00-00-00-00-00
NOARP MTU:1476 Metric:1
gretap0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
BROADCAST MULTICAST MTU:1462 Metric:1
ifb0 Link encap:Ethernet HWaddr 9A:7C:8F:36:C9:53
BROADCAST NOARP MTU:1500 Metric:1
collisions:0 txqueuelen:32
ifb1 Link encap:Ethernet HWaddr 1A:D0:AF:FD:59:54
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%2/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:201 errors:0 dropped:0 overruns:0 frame:0
TX packets:201 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:14687 (14.3 KiB) TX bytes:14687 (14.3 KiB)
wlan0 Link encap:Ethernet HWaddr E4:95:6E:40:B4:D3
RX packets:1576 errors:0 dropped:0 overruns:0 frame:0
TX packets:1417 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:236846 (231.2 KiB) TX bytes:490411 (478.9 KiB)
Looks like it didn’t create said interface. Does this mean that it’s not a HiLink model? Are there any other ways to get the right drivers onto my AR300?
Under Tethering, where is also nothing to be found.
The stick itself work, I tested this under MacOS with the generic Huawei drivers. The attached screenshot was made there.
