I need a little help getting my Huawei E3372 (BT Mobile piggyback of EE network here in UK) setup with the AR300M (Firmware 2.25) - At the moment if I attempt to add a new 3G interface, It keeps saying “plug in your modem” and I get no result when I do plug it in. I read in another thread that the e3372 uses the same IP as the AR300M, and that this causes a conflict. I’m not sure how to change the ip of either however.
Ok - all working now, I changed the routers ip: wireless status > Lan ip
The Huawei actually shows up as a tethered device rather than a 3g interface.
Thanks for sharing the solution.
thanks for sharing.
This is annoying that Huawei use the same default LAN IP as us …
Maybe need to change to others e.g. 192.168.11.1 but afraid that there will be a lot of guy screaming, why cannot we access 192.168.8.1
This can be changed dynamically to avoid conflict but we need to use a DNS e.g. console.gl-inet.com for it. Planning for it.
