I Can't use NSA Spitz AX
i keep trying
AT+QNWPREFCFG="nr5g_disable_mode",1
gives an ERROR
i select band masking and block SA doesnt work
i do band masking NSA Open along with LTE doesnt work
im using Verizon
without the one works just gives
+QNWPREFCFG: "nr5g_disable_mode",0
OK
Merge to Can use NSA Spitz AX
