Hi.
I’m using the latest imagebuilder (GitHub - gl-inet/imagebuilder: Warning!Please look at 'GL.iNET Imagebuilder Introduction' section.) , I want to create an image for the ar300m16 with the following packages preloaded:
tcpdump wireless-tools usbutils block-mount e2fsprogs fdisk curl nano coreutils-timeout kmod-bluetooth bluez-libs bluez-utils kmod-usb-core usbutils
but, when I execute the imagebuilder to create the image for this target, it fails and show this error:
./gl_image -p ar300m16 -e “tcpdump wireless-tools usbutils block-mount e2fsprogs fdisk curl nano coreutils-timeout kmod-bluetooth bluez-libs bluez-utils kmod-usb-core usbutils”
Collected errors:
** * check_data_file_clashes: Package busybox wants to install file /home/wavemedia/Documents/openwrt/imagebuilder/imagebuilder/3.0/openwrt-imagebuilder-ar71xx-generic/build_dir/target-mips_24kc_musl/root-ar71xx/usr/bin/timeout**
** But that file is already provided by package * coreutils-timeout**
** * opkg_install_cmd: Cannot install package busybox.**
Makefile:149: recipe for target ‘package_install’ failed
make[2]: *** [package_install] Error 255
Makefile:108: recipe for target ‘_call_image’ failed
make[1]: *** [_call_image] Error 2
Makefile:192: recipe for target ‘image’ failed
make: *** [image] Error 2
Failed to build gl-ar300m…
But if I remove the the coreutils-timeout package, the image builder creates the image with no problem. what could i do to include the coreutils-timeout package?
Also, seems the imagebuilder it is just creating the nor flash image, how could I create also the nand flash image? (I want both images have the same preloaded packages)
Thanks!
