What is your phone’s operating system. Is App file access granted? Can you upload a wireguard profile?
The open vpn configuration file does not support manual addition. So after you click on add you will go to the phone file selection page which is provided by the operating system.
I use Android - latest Build and update
-App/Android doesn´t ask for file access at any time
I looked in the app permission (even extended ones), but no entry “file access” here. (Btw, I know this permission …)
In OpenVPN the Button “Add Configuration” doesn´t do anything
In WireGuard the Button “Add Configuration” shows those three entries.
“Scan” and “manual Input” work, but “Upload” has no reaction, no input possible. (screenshot)
Yes, looks like it´s a problem with “file access”, but there is no way/entry to give permission
My workaround to add the file was right now to use another PC with LAN connect. But I would like to have the possibility in the app too - there´s not always a system connected by LAN…
I once again deleted storage and cache and than deleted the app.
Reinstalled and started the app.
Been asked for permission for location. Granted it (while using the app).
No more permissions were asked.
Went through settings to OpenVPN → Button “Add Configuration” - and again nothing happens and no ask to give file permission.
I guess it´s a “problem?” with Android 13 (with latest updates from August 2023) that is installed on the phone - or the app is not “compatible” with this version? Just a guess as no other app (and there are plenty on the phone) shows this issue.
Well, maybe updates (app or Android) might solve this prob in the future.
