here is a guidance of how to install DDWRT on GLI routers and how to configure OpenVPN using free FinchVPN account.
Please check and test.
How about dd-wrt for AR150? I see the lines about using a carambola2 firmware has been crossed out in your post here: http://www.gl-inet.com/using-ddwrt-openvpn-in-gl/
Tested on AR150 result a failure. So need some more exploration.
Any update on OpenVPN on the AR150? Thanks
Greetings after Christmas holiday!
We hope to test asap.
Just wondering if there has been any progress.
thanks
@skeltonl, I tried but not successful. Maybe just ask DDWRT to add support for the router is easier.
Appreciate that DDWRT is difficult but is there any way to use a VPN service (not just passthrough) with your routers?
Yes. There is a discussion here:
Need a lot of manual work. If I have time, I would like to provide a special firmware.
