I would like to install the wireless driver for my Brume2, but it is missing a package called:
I downloaded a compatible openwrt 21.02 package and was able to start installing the mt76 kmod, however as soon as I installed the mt76 usb and mt76x02 drivers, the brume2 crashed and I had to factory reset.
The vpn-policy issues I’ve had aside, using the brume2 for mwan between ethernet, cellular, and wifi is the reason I bought the brume2 as a vpn gateway. I will just switch to a raspberry Pi if this is not an option.
