Installation of node-red in GL-XE300 Puli router
Hi folks,
I am using GL-XE300 Puli router with OpenWRT firmware. I want to install node-red in this device. Does this router support the node-red? Are there any steps to install the node-red?
Try it and report back if it worked :wink:
The router itself supports many OpenWrt packages.
