I have installed TOR package from the app repo. Haow can I make it work?
You need to download the tor firmware directly.
Tor itself doesn’t have an UI
Sorry for the noob question: if I flash the TOR firmware would it replace the default admin UI? I mean will I lose all the options in the web ui?
Yes, that is correctly. Tor has its own UI.
Thanks very much for your response. How about Shadowsocks? Do I need to flash a separate firmware for that one too?
SS is in the firmware already. You need to configure using Luci.
