Firmware 2.262. Settings = VPN Enabled / Force VPN / Not Started (I uploaded a dummy .ovpn to achieve this).
Router can both check for firmware update (2.263) and also download new update! This is contrary to “No Internet if VPN is not connected” as per the GUI. Also, it makes me wonder what other exceptions to this rule there are hidden away somewhere! For me no internet means exactly that - NO INTERNET.
Second, weather there is Internet or not, only refers to the devices connected to the router, not the router itself. The router need to connect to the Internet all the time.
If you want to achieve something as you said, then there is a loop.
VPN cannot connected -> router has no Internet -> Router will not reach the VPN server -> VPN will not be connect.
The router cannot connect to a VPN if the VPN is required for it to connect, it will only pass traffic though the VPN from the LAN interface to the VPN interface, yet the router still have full inet access as required to find the VPN server and connect to it.
By default all your internal services will use the VPN when then VPN is activiated. Openvpn pushes these 2 routes which shortcuts your default gateway, unless you are using split VPN
route add 0.0.0.0/1 via 10.8.8.1
route add 128.0.0.0/1 via 10.8.8.1
