Internet says connected but cant load any webpages
I've tried connecting to multiple different networks. On both the Beryl and Slate. It says connected in the admin portal. Vpn is off. But when I try to load any webpages, none of them load.
Firmware:
Logs:
Thu Aug 29 21:40:57 2024 daemon.notice wpa_supplicant[2497]: sta0: SME: Trying to authenticate with 76:d9:a0:26:44:9e (SSID='Samsung Galaxy S9+_9702' freq=5805 MHz)
Thu Aug 29 21:40:57 2024 kern.info kernel: [ 132.936739] sta0: authenticate with 76:d9:a0:26:44:9e
Thu Aug 29 21:40:58 2024 daemon.notice wpa_supplicant[2497]: sta0: Trying to associate with 76:d9:a0:26:44:9e (SSID='Samsung Galaxy S9+_9702' freq=5805 MHz)
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.044678] sta0: send auth to 76:d9:a0:26:44:9e (try 1/3)
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.047217] sta0: authenticated
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.054441] sta0: associate with 76:d9:a0:26:44:9e (try 1/3)
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.056789] sta0: RX AssocResp from 76:d9:a0:26:44:9e (capab=0x11 status=0 aid=1)
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.060597] sta0: associated
Thu Aug 29 21:40:58 2024 daemon.notice netifd: Network device 'sta0' link is up
Thu Aug 29 21:40:58 2024 daemon.notice netifd: Interface 'wwan' has link connectivity
Thu Aug 29 21:40:58 2024 daemon.notice netifd: Interface 'wwan' is setting up now
Thu Aug 29 21:40:58 2024 daemon.notice wpa_supplicant[2497]: sta0: Associated with 76:d9:a0:26:44:9e
Thu Aug 29 21:40:58 2024 daemon.notice wpa_supplicant[2497]: sta0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Thu Aug 29 21:40:58 2024 kern.debug kernel: [ 133.086668] sta0: Limiting TX power to 0 (-128 - 0) dBm as advertised by 76:d9:a0:26:44:9e
Thu Aug 29 21:40:58 2024 daemon.notice netifd: wwan (7667): udhcpc: started, v1.33.2
Thu Aug 29 21:40:58 2024 daemon.notice netifd: wwan (7667): udhcpc: sending discover
Thu Aug 29 21:40:58 2024 daemon.notice wpa_supplicant[2497]: sta0: WPA: Key negotiation completed with 76:d9:a0:26:44:9e [PTK=CCMP GTK=CCMP]
Thu Aug 29 21:40:58 2024 daemon.notice wpa_supplicant[2497]: sta0: CTRL-EVENT-CONNECTED - Connection to 76:d9:a0:26:44:9e completed [id=0 id_str=]
Thu Aug 29 21:40:58 2024 daemon.info gl-repeater[2029]: (repeater.lua:380) connected to Samsung Galaxy S9+_9702
Thu Aug 29 21:40:58 2024 daemon.notice netifd: Network device 'wlan1' link is up
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.325493] ath11k c000000.wifi: bss color param 0x81000000 set on vdev 1
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.325813] br-lan: port 4(wlan1) entered forwarding state
Thu Aug 29 21:40:58 2024 kern.info kernel: [ 133.331306] br-lan: port 4(wlan1) entered forwarding state
Thu Aug 29 21:40:58 2024 daemon.err stubby[2772]: Could not schedule query: None of the configured upstreams could be used to send queries on the specified transports
Need to see the firmware version, more info in the repeater part.
Also provide the log.
@alzhao I just added the requested Firmware and the Logs to the original post.
I'm not sure specifically what else you are looking for in the Repeater? Let me know and I'll post it.
Can you show me the screenshot of the Sumsung connection part, including IP address, netmask etc.
Then pls ssh to the router and do these
ping 1.1.1.1
ping google.com
