I can’t access http://192.168.8.1/ on my IOS tablet is this normal ?
Depends on how your router is configured?
Maybe try to use the GL.iNet app instead.
Check the IP of your iOS device.
I have the app but had problems with connecting the router to the app after I fiddled around in the app to troubleshoot so I set the router to guest and it doesn’t work
What should the IP on IOS say sorry ?
When I say guest I mean
GL-AR300M-03b-NOR-guest
The word guest is now added to the end and wasn’t when router was working ;/
You can't join the guest network and have access to the routers GUI.
You need to join the regular network.
