IP address on device panel
The IP address is different between what is shown on the device’s screen and the GLI app toolbox left panel. The mac address is the same. The last few digits are different - it’s the device’s panel which is pointing to an IP which that doesn’t exist on the LAN at all (maybe a previous IP of the device).
Which IP address is actually usable? Will there be different results when re-entering the KVM console or refreshing the page?
Well the IP listed on the device panel is not correct, assuming its pointing to the IP of the device. The GLI software allows me to connect without worrying about the IP so long the device is on, but this becomes a possible issue if the device is in sleep mode as I don’t know if since the IP has changed and it is sending the wake command to a dead IP. I still await to test the wake from sleep feature for this reason.
If you're using both Ethernet and Wi-Fi, the device will have two IP addresses for local access. Try disabling one connection and see if the IP changes.
It is only connected via WIFI
Could you please provide your system log and app logs?
Email: flora.wan@gl-inet.com
