I have a GL-AR-150 running firmware 2.24. I can get the GL-AR-150 setup working when I connect it to my router via the WAN port. WiFi works fine and I have internet access. If I disconnect the GL-AR-150 from my router and plug my iPhone 6S Plus into the USB port on the GL-AR-150 I can have no connection to the internet thru my phone. All I see on the web interface is “Connecting to the Internet” which never goes away and I have no internet connectivity.
The hotspot on my iPhone requires a password but I’ve never been prompted for a password on the GL-AR-150. I have the iPhone connected with a USB cable and the iPhone shows up in the web interface as eth2, so the GL-AR-150 seems to see the iPhone. What do I need to do to make the GL-AR-150 connect to the internet using my iPhone?
I have not seen any prompt asking about Trust when plugging the iPhone into the GL-AR-150. My iPhone is a iPhone 6S Plus running IOS 10.2
Is there any way to force the Trust message to appear on the iPhone? Does the GL-AR-150 need to be connect to my router for this to happen, or have something plugged into the GL-AR-150 LAN port before the Trust message will appear?
I managed to get the pop up that asks if you “Trust this computer” by resetting my network connections on the iPhone. The iPhone now tethers to the GL-AR-150 without any issues now.
