I did what you told me agent smith, the connection with the PC is done automatically, I see my iPhone, I connect to it either directly, or with others. But nothing works,
On the iPhone, the blue bar never flashes when it is connected, it remains fixed. the LEDs are white, not blue or green on the modem MT300N.
Hmmm strange enough…, do you see something like “udhcpc: received SIGTERM” followed by “apcli0” is down at the time you connect mango to iphone on luci system log? If yes try my last suggestion :
Go to luci >> system >> startup
Search gl-health, stop and disable it
Restart mango
Do my first suggestion above once again (with ethernet cable)
My iphone not always has blue bar when its succeed to connect and give internet access to mango, I don’t know its ios bug or what.
If the problem persist, then I have no more ideas, maybe change your internet sources
None of your methods are working.
The LEDs on the Mango stay white all the time, they shouldn’t change color when it is powered on or connected,?
Can I connect with my modem?
But not with my iPhone!
