I need help to configure the custom-rules on the GL Inet.
During active openvpn connection I can’t connect to the NAS on the other local network of the fritzbox router, when I switch off openvpn all is working.
Of course all other communication shut run over openvpn!.
I deleted previous post as I overread some information, which made my post senseless.
Nevertheless, as you have written that Netflix and other also should not use the VPN would it be an option to rather specify what should use VPN instead of what should not?
I agreed. First it should work, therefore I would first try the other way around, because if that also is not working, it may be easier to rule out other options.
You could try adding this to your openVPN client config
