IPTV Question
Hello all.
I have a GL.iNet GL-X3000 (Spitz AX). I am getting good speeds at home. I am going to use this device in my semi truck in US.
My problem is i want to watch IPTV on the road but iptv keeps freezing every 3 seconds for a very short time on tablet ( ipad 10th gen). This does not happen if i connect the ipad to our home wifi.
Same thing haopens when i try on my phone with this device.
Any ideas how to fix this problem.
Thank you in advance.
Did you use VPN?
Is the topology like this?
iPad --- Spitz AX router with VPN client --- VPN server --- Home ISP router
No VPN.
Well, i just got a VPN service and looks like it solved the freezing problem on ipad. I will test it when i am on the road and see if stays this way :slight_smile:
Without VPN between the home to travel router, how can I see the contents of IPTV? is the IPTV provided by ISP operators from home cable?
