IPv6 Firewall support
Hi all,
I see on the IPv6 page that some IPv6 features are not yet available (as Firewall support). Is there a way to find out if and when they’ll be available? I’d like to use LuCI only if needed, and some functionalities are really easier and more appealing on the GL.iNet proprietary interface (while I appreciate when the two systems are interchangeable).
Have a nice day :slight_smile:
The "firewall" here primarily refers to the DMZ and port forwarding features within the GL UI.
The "Open Ports on Router" feature should already be functioning correctly to open ports on both IPv4 & IPv6.
The former may be improved in version 4.9.x, but there is currently no timeline information available to share.
