I want some destination IP goes through cable, and some through USB tethering. Is it possible to do so? Thanks.
It is possible but may not work brilliant.
You need to change settings in /etc/config/network and /et/config/mwan3
The “metric” value means priority. A low metric mean high priority. If two connections have the same metric, it will loadbalance.
