Is it possible to swap Command and Alt for MacOS
I am using a Windows 11 PC to access a remote Mac. The device I’m using is Comet Pro with latest V1.8.0 release4.
By default “Windows key“ is acting as “Command key“ on Mac. There is an option to “Swap Command and Ctrl for MacOS“, so we are receiving kind of Windows experience on Mac (Ctrl+C, Ctrl+V, etc.).
I’m wondering is there a way to swap Command and Alt for MacOS?
I’d like to have basically default order of keys even when connecting from Windows: Ctrl, Option, Command, Space, etc. (if going from left bottom corner of keyboard)
I believe that you can do this in OSX directly via System Settings > Keyboard > Keyboard Shortcuts > Modifier Keys. That may not be great if you use a Mac keyboard locally as well, but if you're mainly using it with a Windows keyboard it may help.
