Is there a difference between flashing via recovery or flashing via webinterface?
On a AR750 firmware can be flashed via 2 ways:
  1. by holding the reset button, powering up and going to 192.168.1.1
  2. by uploading the firmware through the web interface
Is there a difference between these two? Is one doing more or different things than the other? (Except the one being brick recovery)
Option 1 you can flash anything, like a non compatible firmware which can brick your router. That is, it does not verify your firmware.
Option 2 will verify your firmware. You can also reserve settings if you want.
