Is There MAC address Filtering?
I Have A Flint. I'm looking for the feature I can't find. It's A top model feature. Where is It.
Found it, under Clients.
Screenshot of how you do this.
Yes, It not So obvious A heading, easy to miss the Small link to Blocklist.
Once I Added a Client to the Access List, does that mean ONLY that Lan can connect thereon?
If you add one client to "block list", it may means that the client is blocked on both LAN and wifi.
NO, I Was talking about the Access list, Does It go live.
Right I’ve Tested this. No Other Clients Can connect unless there on the list.
