using Beryl-MT-1300 and have working wirguard/ovpn
I travel around and test wifi to home Beryl-mt-1300 ,so i get home dedicated ip
some isp are blocking ,dropping wireguard handshakes but allowing openvpn
some others have deep packet inspection and dropping both vpns openvpn and wireguard
already tried to use port 443 as inbound
using port 53 as inbound is not working for some reason ?
found few articles to use localproxy socks5 but im not using linux box at home and not sure if works
if any work arounds using Beryl-MT-1300 to get wireguard or openvpn when isp is dropping all ?
If they use DPI you can't get around it, I am sorry.
At least not with a default setup and without using plain OpenWrt.
What is a solution that can work to connect home VPN even with deep packet inspection drops
Is there a localhost setup
Shadowsocks might be helpful; but not supported in GL firmware.
From reading on red dit ,the handshake if routed via proxy can work but not fully understand it's setup via a tiny Linux server in cloud
Don’t know if this will help (fouling TG chat):
#!/bin/sh
echo "WARNING: Proceeding will modify network configurations."
read -p "Do you wish to continue? (y/n): " confirm && [[ $confirm == [yY] ]] || { echo "Aborted."; exit 1; }
read -p "Select mode: 1 for Client, 2 for Server: " mode
case $mode in
1)
read -p "Enter your Shadowsocks server IP: " SS_SERVER
read -p "Enter your Shadowsocks server port: " SS_PORT
read -p "Enter your Shadowsocks password: " SS_PASSWORD
read -p "Enter your Shadowsocks encryption method (e.g., aes-256-cfb): " SS_METHOD
opkg update
opkg install shadowsocks-libev curl
CONFIG_JSON=$(cat << END
"server":"$SS_SERVER",
"server_port":$SS_PORT,
"local_address": "127.0.0.1",
"local_port":1080,
"password":"$SS_PASSWORD",
"timeout":300,
"method":"$SS_METHOD"
END
echo "$CONFIG_JSON" > /etc/shadowsocks.json
ss-local -c /etc/shadowsocks.json &
echo "Client setup completed successfully."
2)
opkg update
SERVER_CONFIG="/etc/shadowsocks-server.json"
cat << EOF > $SERVER_CONFIG
"server":"0.0.0.0",
"local_port":1080,
"timeout":300,
EOF
ss-server -c $SERVER_CONFIG &
echo "Shadowsocks server started successfully."
check_connection
echo "Invalid mode selected. Exiting."
exit 1
esac
revert_changes() {
rm /etc/shadowsocks.json
killall ss-local ss-server
opkg remove shadowsocks-libev
iptables -F
ip route flush table 100
ip rule del fwmark 0x01
echo "Changes reverted."
check_connection() {
wget --quiet --spider https://google.com &>/dev/null
if [ $? -ne 0 ]; then
echo "No Internet"
read -p "Do you want to revert changes? (y/n): " revert_choice
if [[ $revert_choice == [yY] ]]; then
revert_changes
else
echo "Not reverting changes."
fi
fi
check_connection
