I’ve got a MT300A, I’ve just installed the TOR firmware and I’m having a couple of issues. The switch on the side seems to have no impact, in either the left or right position I can access the UI and login (I’ve tried closing my browser, clearing history, rebooting the router etc). The Tor connection status shows connected in either position. I was running 2.25 before I changed the firmware.
Having read the docs I should only be able to view the UI with the switch is to the right and TOR should not be connected. Is this correct?
I never fixed this. When I used https://check.torproject.org/ it said I wasn’t connected and my question above was never answered. Since I don’t really use Tor it wasn’t really an issue but would have nice to have fixed it.
I’m having the same issue, except mine is on the v2 model… Tor says it’s connected but nothing is being routed via tor. I connect directly to my modem and Tor doesn’t work… Not to mention the wireless scan when trying to connect the wan to an ssid, doesn’t work. Manually entering an ssid also doesn’t work…
But, Tor is broken in this firmware. Switch on the left or right… UI says tor is connected, but nothing goes out via TOR. Frustrating…
I’ve seriously been having nothing but problems ever since I flashed to Tor.
So I was finally able to boot web failsafe and just like everything else I’ve tried - it didn’t do what it was supposed to.
I followed the instructions exactly (kinda hard to mess up, and I watched the video on youtube) and tried several times and with both the WAN and LAN ports.
When I tried the uboot fail safe, the 3rd LED (the one on the far right when you’re facing the front of the router) blinked RED exactly 4 times, and then the second LED went full green. The first LED was full green the entire time.
notes I have a yellow, GL-MT300N-V2. After initially receiving the router, I “upgraded” the firmware through the UI to the current version. At this point I should have entered my information for my VPN, but I didn’t (I thought I’d come back to it later because I hadn’t bought the VPN service yet). Then I flashed to the Tor firmware and I couldn’t get the check tor page to say I was using Tor. After watching a video on youtube, it seems that there is some sort of open connection that I (along with probably most of the other ppl having problems), need to disable. At that point Tor should work.
However, I’m trying to get both Tor and and a VPN to work.
This is my exact problem as well. I have the same box as you. When I connect the wan via physical cable I can see the TOR status is connected, but nothing gets routed out tor. It doesn’t matter if I am using the wifi or ethernet. Like you said, it seems like there’s a route that needs to either be disabled or a route that needs to be configured to get Tor to work. Not sure how this is so difficult. It’s supposed to work out of the box. Anyway, i’m looking at a few sites that deal with lede and Tor specifically, and looking at their shh commands/configs. It may take me a few days but if I figure anything out, I’ll report back.
Devs should really look into this. Right now Tor firmware for MT300N-V2 is broken and doesn’t work at all. Also, documentation if poor at best. I understand and appreciate the effort… But I think things are getting lost in translation perhaps.
yeah the third LED is your wireless interface. So if it’s blinking red that means there’s data transmission. The first LED is power, and the second is nothing (if I recall correctly). If you use the TOR firmware, the second LED is the TOR connection status.
Otherwise, you can program that LED to be whatever you want… I haven’t played with it yet to figure out how to do that…
