I have two GL-AR750S units. I have one setup on my local network and configured as a VPN Server using OpenVPN (I’ll refer to this as the Server).
I have another unit setup on another remote network that is connected to the Server as an openVPN client. (I’ll refer to this as the Client)
I can access the Client AR750S control panel via the 10.8.0.x address that it has from my local network. However, I cannot access any of the resources on the Client network.
The Client device I am trying to connect to is an NVR. I can find the IP address, but am unable to ping it as it seems to be blocked by what I am guessing is the Client AR750’s firewall. I setup firewall rules to open up the ports I needed, and even tried putting the device I wanted to access in the DMZ. Still no luck.
Any ideas on how I can access a device on the Client AR750 network when it’s connected to the VPN from the Server’s local network?
Thanks in advance!
